Yaskawa Europe
Welding cobot in action
With a major order from a neighboring customer, Stöckl Maschinen und Gerätebau in Schliersee was ready: The company ventured into robot-based welding - with a CE-capable complete cobot cell from Yaskawa.
The Cobot 'HC10DT IP67' is designed in protection class IP67 and is therefore protected against welding splashes in the production process.
© Yaskawa Europe
Success literally came overnight for Holztec-Leitner from Schliersee in Upper Bavaria: company boss Franz Leitner had barely put his self-designed and handmade swing and relaxation loungers made from larch and spruce wood in an online store when the first orders started coming in. Today, the 'sky loungers', which are protected by European design standards, can be found on terraces, in gardens and parks as far away as Mallorca and Italy. In order to be able to deliver the high quantities required on a permanent basis, a partner was needed to manufacture the solid metal swivel frames, as the 'sky loungers' can be rotated 360°.
In his search for a suitable specialist company, Franz Leitner found what he was looking for at Stöckl Maschinen und Gerätebau in Schliersee. Founded in 1989, the company specializes in the manufacture of welding and assembly components made of steel, stainless steel and aluminium. These are used in traditional machine and equipment construction, but also in rail and special vehicles, for example. Until the inquiry from Holztec-Leitner, however, the designs were usually only produced in small batches and predominantly manually. Nevertheless, at the end of 2020, Managing Directors Kamil Kowalski and Christian Strobl took on the challenge of welding several hundred bogies per year in the future - automated welding. They were looking for a compact robotic welding system that was both quick to commission and easy to operate.
Stöckl Maschinen und Gerätebau now automatically welds up to 1000 bogies per year.
© Yaskawa Europe
The choice fell on the 'Weld4Me' cobot welding cell from Yaskawa, which combines the advantages of a collaborative robot and a simple user interface with professional welding functions in a compact form. The manufacturer is thus enabling small and medium-sized companies that have previously welded by hand to enter the world of automated robotic welding.
The cell went into operation at Stöckl Maschinen und Gerätebau at the beginning of 2022. As a special feature, it is equipped with magnetic holders instead of the usual clamping devices. "The cut-to-size profiles are simply inserted and held in place magnetically at the touch of a button," says Kamil Kowalski, describing the process. "This ensures that the components are always in exactly the same position."
In detail, the cell consists of a Cobot 'HC10DT IP67', a 'YRC1000' controller with functional safety unit (FSU), welding table, glare shield and other optional features and extensive welding functions for MIG/MAG welding. The collaborative robot is designed in protection class IP67 and is therefore protected against welding spatter in the production process.
Programming via teachbox or manual guidance
Franz Leitner from Holztec-Leitner and Kamil Kowalski and Christian Strobl from Stöckl Maschinen und Gerätebau (from left to right).
© Yaskawa Europe
The complete cell takes into account the requirements for human-robot collaboration in the risk assessment and ensures safe welding operation thanks to the safety setup. This means that the robot can be set up directly without a fence using integrated torque sensors. As soon as the curtains are closed, it then works in industrial mode. This means that even more complex welding tasks can be programmed on the 'HC10DT IP67' in two alternative ways: classically using a teach pendant (teach box) or by means of manual guidance (direct teach) of the cobot arm. Stöckl Maschinen und Gerätebau currently still prefers programming via teachbox.
The author: Jürgen Riedinger is Senior Sales Manager GI Robots & Products at Yaskawa Europe - Robotics Division in Allershausen.
© Yaskawa Europe
Nevertheless, Managing Director Kamil Kowalski also appreciates the cobot-specific option of hand-guided programming. This is because new welding positions can be easily approached and programmed on the simplified 'Welding Wizard' user interface using manual guidance of the collaborative robot. Control buttons on the flange also make it easier to program the welding job. Once the program has been created, the robot path can be checked again in a dry run before the robot starts its welding work. Teaching in complex programming environments is no longer necessary, leaving more time for the actual welding process. This solution is particularly suitable for small batch sizes and a wide variety of products, as it minimizes the effort required to change over to a new part.
The cobot welding cell has been in operation at Stöckl Maschinen und Gerätebau since the beginning of 2022: the annual throughput is now around 1000 bogies.
Robotics
Michael Ardelt becomes first COO at Robco
Robco, a company for autonomous industrial robotics, is further expanding its management team. As the company's first Chief Operating Officer, Michael Ardelt will assume responsibility for structuring and scaling Robco's growth in operational terms.
Humanoids
Schaeffler cooperates with VinDynamics
Schaeffler and VinDynamics, a company of the Vietnamese Vingroup, have agreed on a strategic partnership in the field of humanoid robotics. The collaboration focuses on the development and supply of planetary gearboxes, central components of...
