Baumer
Inka Krischke | Tiffany Dinges,
Reliably recognize the finest details
Baumer is expanding the 10 GigE cameras in the 'LX' series with four new models. The cameras with Sony Pregius S sensors deliver 50 fps at 24 megapixels; more resolution is available with the 65 megapixel Gpixel models at 18 fps.
© Baumer
The models with Sony Pregius S-IMX530 sensor offer reduced shading effects thanks to backside illumination pixel architecture and, according to the provider, excellent image quality for stable evaluations. A compact optical format of 4/3 inch is made possible by the small pixel size of just 2.74 µm. Thanks to the C-mount, a variety of standard lenses are available for every application. If better image quality is required, TFL mount lenses can be used.
The GMAX3265 sensor from Gpixel used in the 65 megapixel models offers a dynamic range of 66 dB. The pixel size of just 3.2 µm results in a compact optical format with a diagonal of 37 mm.
This simplifies lens selection based on the M58 mount and reduces edge shading. Thanks to a minimum exposure time of 19 µs, motion artifacts can be reduced even at high object speeds, according to Baumer. Based on the M12 connectors, IP65 and IP67 as well as a temperature range of -30 to +60 °C, the cameras are particularly suitable for difficult environmental conditions.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Baumer
The all-round view
Rotationally symmetrical objects in the pharmaceutical, food and beverage industries are often rotated once around their own axis during inspection and the images captured in the process are compiled afterwards. An alternative is a system with four...
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
Baumer
Measured value is available in 15 s
The CombiLyz conductivity sensor from Baumer helps with the phase separation of food, water and cleaning liquids. It measures the electrical conductivity of the passing medium and draws conclusions about the type of medium and its concentration.
