Meilhaus
Inka Krischke | Tiffany Dinges,
Web-based measuring system with cloud connection
The Dydaqmeas DM-800-8P is a measurement system from Dydaqlog with a quad-core ARM Cortex-A72 processor (1.5 GHz clock rate) and integrated web server.
© Meilhaus
Eight differential, individually configurable analog inputs with 24-bit resolution and up to 256 kHz sampling rate each are available for voltages, currents or the direct connection of IEPE sensors. There are also six TTL-compatible digital inputs that can be used as capture and quadrature decoder inputs. According to Meilhaus, the processor intelligence enables many operations to be carried out directly in the device, for example channel calculations, FFT, threshold monitoring with alarm, switching reaction or sending e-mails. Communication with the device takes place via WLAN or LAN. The MQTT protocol is supported for transferring individual values to a cloud, as is the FTP protocol. The web interface enables the design and assignment of different dashboards for any number of users.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
