Flir
Thermal imaging camera with improved analysis
'Flir T865' is a high performance thermal imaging camera of the T-Series from Flir Systems for the inspection of electrical and mechanical equipment as well as for research and development applications.
© Flir
The thermal imaging camera from Flir offers a temperature measurement accuracy of ±1 °C or ±1 %, a temperature range between -40 and +120 °C and in-camera tools for improved analysis. Thanks to their temperature measurement accuracy, the condition of systems can be checked and assessed regardless of the test interval or changing environmental conditions.
Portable and fixed handheld versions are available for indoor and outdoor applications in harsh conditions, as well as a choice of multiple lenses for inspecting objects at close and long range. A 6° telephoto lens provides the magnification required for those who regularly need to check the condition of small targets from a greater distance. For inspections through an IR window, a 42° wide-angle lens and in-camera transmission matching allow precise measurements of targets located in enclosures.
EVT
Non-destructive testing
With the solutions for non-destructive testing (NDT) in the image processing software 'EyeVision 4' from EVT, the extended command set for NDT is available. According to the provider, this simplifies the detection of cavities or other structures...
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
