Programming system
Quelle: Ertec | Lukas Dehling,
Galvanic signal isolation possible
The HTV subsidiary Ertec offers the newly developed Ertius onboard programming system. According to the manufacturer, it enables extremely fast, reliable and efficient programming directly on the production line for high-speed flashing of assemblies.
© Ertec
© Ertec
Up to four programming heads can be reliably controlled via long cables of up to 5 m - with galvanic signal isolation if required. The individual programming processes run autonomously and independently of each other, which enables parallel programming of the same or different device types with identical or different programming data. Project-specific customer requirements such as serial number programming, restoring and modifying sample-specific production data or setting up write and read protection should be easy to implement thanks to the flexible structure.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
