KEB AUTOMATION
OPC UA Server implemented
The compact C6 Smart top-hat rail IPC and the C6 S14 panel version with touchscreen (resistive or capacitive) are tailored to the runtime environment and real-time capability.
© KEB Automation
The OPC UA server implemented in each case enables users to exchange data on a platform-independent basis using TCP. This simplifies networking in accordance with Industry 4.0. The OPC UA server receives its data via the symbol configuration of the 'Combivis studio 6' development tool and communicates with suitable OPC UA clients from different manufacturers that provide and receive the same data structures. According to the manufacturer KEB Automation, the optimized processor performance enables users to solve synchronous motion control tasks.
A standard micro UPS, in conjunction with four independent mass storage devices for the operating system, runtime environments, non-volatile data and user applications, make both devices robust and reliable systems.
In addition to integrated real-time control, the smart IPCs can handle visualization and also offer integrated remote maintenance functions.
KEB Automation
Use in disk motors
The Combistop 38 spring-applied brake from KEB Automation is often used as 'Version 38S' in disc motors, for example. Its reduced overall length allows it to be used even in tight installation spaces.
TTTech
The configuration
Time-Sensitive Networking must offer a standardized communication platform for machine builders and automation engineers alike - the TSN configuration must support both worlds without conflict. How and with which approach can this be achieved?
