Spectra
Edge Device with NVDIA Orin NX
The 'AIE-KN41' edge device from Spectra combines NVIDIA's 'Jetson' series, a compact design and AI performance in one system. It is based on the Orin NX platform.
© Spectra
According to Spectra , the small design and weight of just 500 g make the edge device one of the most compact edge AI systems on the market. This allows edge computing to be integrated into existing systems and effectively placed in environments with limited space. The edge device offers an AI performance of 100 TOPS (tera-ops per second) and is therefore suitable for applications such as machine learning and image processing. The device is equipped with a 6-core Arm Cortex-A78AE-v8.2 CPU with 2 Mbyte L2 and 4 Mbyte L3 cache. The memory options of 16 Gbyte 128-bit LPDDR5 with a transfer rate of 102.4 Gbit/s provide sufficient capacity for data-intensive applications. The edge device consumes only 7.6 W in idle mode and 40.25 W under full load.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Advantech
Edge AI HPCs for Vision AI and GenAI
Advantech has announced the 'AIR-410' and 'AIR-420', next-generation compact Edge AI high performance computers (HPCs). Combining AMD Ryzen 7000/8000/9000 series processors, scalable GPU support and Advantech's 'Edge AI SDK' software, the systems...
