SSV
Yvonne Junginger,
IoT building blocks for edge gateway applications
SSV believes that the development of an industrial IoT application requires solid planning and a DevOps process chain with a development process that covers the entire life cycle of the application.
© SSV Software Systems
To help with the complex requirements for the development of an industrial IoT application, SSV offers an adaptive building block concept for industrial IoT applications. The central functional module is a hardware-agnostic firmware for edge gateways with a customizable range of functions that can be used on various embedded platforms as well as in Docker containers.
The modules of the "SFS" modular system (Smart Factory Sensor) are available for sensor technology in combination with the "SSB" protocol (Secure Sensor Beacon). AI functions are integrated into the firmware via "TensorFlow" and "TinyML". In terms of cybersecurity, various security levels are possible, which are based on the IEC 62443-4-1 directive. The modules are passed on as part of a license agreement.
Lynx Software
When edge and cloud merge
It is becoming increasingly difficult to separate functions that take place in the cloud from functions that are executed at the edge - both worlds are becoming more and more completely dependent on each other. What security risks does this create...
Parasoft
Error-free code, safe application
Static analysis enables software developers to maintain high code quality right from the start. The early and frequent checking for errors and their elimination reduces the workload and helps to avoid software vulnerabilities.
