Deutschmann Automation
Compact communication solution
Deutschmann Automation offers an embedded version of the 'Unigate Falcon' protocol converter/gateway series that can be integrated immediately. The 'Unigate Falcon Embedded' communication solution quickly provides an Industrial Ethernet or fieldbus interface.
© Deutschmann
The embedded version of the Deutschmann series can be integrated directly into existing end products as a complete module without a housing. Thanks to the low installation height of approx. 25 mm, it is also suitable for installation situations where space is limited, as well as for applications where DIN rail mounting of a separate or external protocol converter or gateway is not possible or should be avoided. The device is mounted via four mounting holes, which also allow individual mounting within the product housing. The position and dimensions of the holes are identical in all bus versions. The module is wired within the product, whereby the device configuration or programming can be used. The electronics of the end product do not need to be adapted or changed.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
In focus: IT meets OT
The e-paper of issue 04/2024
What is the current status of Single Pair Ethernet? Are LLMs suitable as intelligent assistants? What is the 'All Electric Society'? The latest issue of Computer&Automation provides answers to these questions. Plus: the winners of the 'Products...
