IDS
Expansion in the lower price segment
The 'Ensenso S' 3D camera from IDS is particularly suitable for 3D applications that require easy-to-integrate, industrial-grade camera technology.
The 3D camera 'Ensenso S' from IDS
© IDS
The Ensenso S10 from IDS in an IP65/67-protected die-cast zinc housing generates 3D data using laser point triangulation, supported by artificial intelligence. It is equipped with a 1.6 MP Sony sensor and works with a laser-based 3D process. A narrow-band infrared laser projector generates a high-contrast dot pattern, even on objects with difficult surfaces or in dimly lit environments. The laser point triangulation is accelerated by a neural network and enables a reliable assignment of the recorded pattern points to the fixed coded positions of the projection. This results in geometrically precise 3D data with high depth accuracy. With object distances of 50 cm, the maximum deviation is 0.6 mm. With full projector power, up to 20 point clouds per second are achieved. The camera has a 60° field of view and a working range of 0.5 to 3 m.
IDS
Software update with new features
Users of the IDS NXT ocean embedded vision system have new features at their disposal, including multi-ROI for AI-based object detection and the option of using different neural networks for different ROIs in one image via the vision app.
IDS
AI marketplace launched
On the IDS virtual AI marketplace, end customers have access to complete image processing solutions and can choose the right, ready-made application. This should open up new opportunities for image processing projects, especially for SMEs.
