Bicker
Industrial mainboards reliably supplied
The DC161W fanless DC-ATX converter from Bicker Elektronik is suitable for mobile applications in 12 V or 24 V on-board power supplies as well as for industrial and medical embedded IPCs.
© Bicker Electronics
Precisely regulated +5 Vsb/ +3.3 V/ +5 V/ +/-12 V are available at the ATX output. The DC/DC converter from Bicker Elektronik with 93 % efficiency is equipped for 24/7 continuous operation in the temperature range from -20 to +70 °C. With a wide-range input of 6 to 36 V(DC), it ensures a stable power supply to the connected mainboard even in the event of major fluctuations in the supply voltage. Its cable management system enables the flexible use of customer-specific cable harness solutions. A suitable thermal pad (gap filler pad) is included in the scope of delivery for the thermal connection of the power components on the underside of the board. The DC/DC converter can be operated both in standard power supply mode and in automotive mode, for example for CarPCs.
Bicker
Flexible system integration
The BE-DCEB10A DC inrush current limiter from Bicker Elektronik protects against high currents that occur when capacitive DC loads are switched on and can damage the power supply or trigger fuse elements.
