Geared motors
Quelle: WEG Germany | Inka Krischke,
Rated torques up to 5000 NM
WEG is expanding its WG20 geared motor range to include helical, parallel shaft and helical bevel gearboxes for rated torques up to 5000 Nm.
© WEG Germany
The gearbox housings are made of gray cast iron and are so robust that they are also suitable for applications such as in the steel and heavy industry. Thanks to the expansion of the geared motor range, applications with higher torques can now also be covered. Thanks to the intelligent pinion construction kit, the gearboxes in the series are designed with two or three stages in a large reduction range. According to the supplier, this results in very low losses and the gearboxes are particularly energy-efficient. In addition, the variant-optimized gearing concept enables high output speeds and the implementation of a wide speed range for all gearbox sizes.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
Lean technology
Easy to implement
Nabtesco
The gearbox makes the robot
How precise, strong and fast a robot is depends on the performance of the gearboxes used. In the white paper, you can find out what is important in the design and how your robot can also benefit from the properties of Nabtesco gearboxes.
Faulhaber
Compact motion control system
The Motion Controller 22xx...BX4 IMC from Faulhaber is already integrated in the brushless motors of the '22xx...BX4' family. The increase in length compared to the individual motor is 18 mm and includes a fully-fledged servo controller and a 12-bit...
