FSG
Wind sensor with obstruction light
FSG developed a wind sensor with an integrated LED obstruction light in close consultation with the customer.
Wind sensor with integrated LED obstruction light from FSG
© FSG
With this wind sensor from FSG Fernsteuergeräte, space can be saved in confined areas at the highest point of crane systems or similar facilities, installation and maintenance costs are reduced, the sensor is more visible and, according to the manufacturer, offers greater accuracy. The wind sensor with obstruction light has an IP66 degree of protection and complies with all relevant regulations and standards of the International Civil Aviation Organization (ICAO) as well as the General Administrative Regulation on the Marking of Obstacles to Aviation (AVV). It can therefore be used without restriction for marking aviation obstacles such as cranes, wind turbines or buildings. The red obstruction light achieves a light intensity of 10 or 32 cd (red), the magnetic wind sensor measures wind speeds from 0 to 50 m/s. The combination is supplied with 18 to 33 V(DC), analog signals or a CAN bus are available as signal outputs.
FSG at the SPS: Hall 4A, Stand 341
FSG
New management structure
FSG Fernsteuergeräte, a provider of measurement and sensor technology, is about to make a change at the top: Klaus-Dieter Schulz is retiring from the management of the company.
Leuze at the SPS 2024
Double focus
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
