Predictive maintenanceMonitoring via ultrasound
Using ultrasound as an alternative to vibration diagnostics for predictive maintenance, for example, has so far been the exception rather than the rule. However, the technology can even increase its potential with a mobile app and storage in the cloud.
<p class="MsoNormal" style="margin-bottom:0cm;margin-bottom:.0001pt;line-height:
150%"><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves></w:TrackMoves>
<w:TrackFormatting></w:TrackFormatting>
<w:HyphenationZone>21</w:HyphenationZone>
<w:PunctuationKerning></w:PunctuationKerning>
<w:ValidateAgainstSchemas></w:ValidateAgainstSchemas>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF></w:DoNotPromoteQF>
<w:LidThemeOther>DE</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables></w:BreakWrappedTables>
<w:SnapToGridInCell></w:SnapToGridInCell>
<w:WrapTextWithPunct></w:WrapTextWithPunct>
<w:UseAsianBreakRules></w:UseAsianBreakRules>
<w:DontGrowAutofit></w:DontGrowAutofit>
<w:SplitPgBreakAndParaMark></w:SplitPgBreakAndParaMark>
<w:EnableOpenTypeKerning></w:EnableOpenTypeKerning>
<w:DontFlipMirrorIndents></w:DontFlipMirrorIndents>
<w:OverrideTableStyleHps></w:OverrideTableStyleHps>
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math"></m:mathFont>
<m:brkBin m:val="before"></m:brkBin>
<m:brkBinSub m:val="--"></m:brkBinSub>
<m:smallFrac m:val="off"></m:smallFrac>
<m:dispDef></m:dispDef>
<m:lMargin m:val="0"></m:lMargin>
<m:rMargin m:val="0"></m:rMargin>
<m:defJc m:val="centerGroup"></m:defJc>
<m:wrapIndent m:val="1440"></m:wrapIndent>
<m:intLim m:val="subSup"></m:intLim>
<m:naryLim m:val="undOvr"></m:naryLim>
</m:mathPr></w:WordDocument>
</xml><![endif]--><span style="font-size:12.0pt;line-height:150%;font-family:"Courier New"">The "UltrasonicSpion" - consisting of an ultrasonic generator, probe and soundproof headphones </span><span style="font-size:12.0pt;line-height:150%;font-family:
"Cambria Math","serif";mso-bidi-font-family:"Cambria Math"">-</span><span style="font-size:12.0pt;line-height:150%;font-family:"Courier New""> reliably detects leaks even in production areas with noisy surroundings.</span></p><p class="MsoNormal" style="margin-bottom:0cm;margin-bottom:.0001pt;line-height:
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
DefSemiHidden="true" DefQFormat="false" DefPriority="99"
LatentStyleCount="267">
<w:LsdException Locked="false" Priority="0" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Normal"></w:LsdException>
<w:LsdException Locked="false" Priority="9" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="heading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"></w:LsdException>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 1"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 2"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 3"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 4"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 5"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 6"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 7"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 8"></w:LsdException>
<w:LsdException Locked="false" Priority="39" Name="toc 9"></w:LsdException>
<w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"></w:LsdException>
<w:LsdException Locked="false" Priority="10" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Title"></w:LsdException>
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"></w:LsdException>
<w:LsdException Locked="false" Priority="11" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtitle"></w:LsdException>
<w:LsdException Locked="false" Priority="22" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Strong"></w:LsdException>
<w:LsdException Locked="false" Priority="20" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="59" SemiHidden="false"
UnhideWhenUsed="false" Name="Table Grid"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"></w:LsdException>
<w:LsdException Locked="false" Priority="1" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="No Spacing"></w:LsdException>
<w:LsdException Locked="false" Priority="60" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="61" SemiHidden="false"
UnhideWhenUsed="false" Name="Light List"></w:LsdException>
<w:LsdException Locked="false" Priority="62" SemiHidden="false"
UnhideWhenUsed="false" Name="Light Grid"></w:LsdException>
<w:LsdException Locked="false" Priority="63" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 1"></w:LsdException>
<w:LsdException Locked="false" Priority="64" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Shading 2"></w:LsdException>
<w:LsdException Locked="false" Priority="65" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 1"></w:LsdException>
<w:LsdException Locked="false" Priority="66" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium List 2"></w:LsdException>
<w:LsdException Locked="false" Priority="67" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 1"></w:LsdException>
<w:LsdException Locked="false" Priority="68" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 2"></w:LsdException>
<w:LsdException Locked="false" Priority="69" SemiHidden="false"
UnhideWhenUsed="false" Name="Medium Grid 3"></w:LsdException>
<w:LsdException Locked="false" Priority="70" SemiHidden="false"
UnhideWhenUsed="false" Name="Dark List"></w:LsdException>
<w:LsdException Locked="false" Priority="71" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Shading"></w:LsdException>
<w:LsdException Locked="false" Priority="72" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful List"></w:LsdException>
<w:LsdException Locked="false" Priority="73" SemiHidden="false"
UnhideWhenUsed="false" Name="Colorful Grid"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 1"></w:LsdException>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"></w:LsdException>
<w:LsdException Locked="false" Priority="34" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"></w:LsdException>
<w:LsdException Locked="false" Priority="29" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Quote"></w:LsdException>
<w:LsdException Locked="false" Priority="30" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 1"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 2"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 3"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 4"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 5"></w:LsdException>
UnhideWhenUsed="false" Name="Light Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Light Grid Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium List 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Dark List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Shading Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful List Accent 6"></w:LsdException>
UnhideWhenUsed="false" Name="Colorful Grid Accent 6"></w:LsdException>
<w:LsdException Locked="false" Priority="19" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="21" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"></w:LsdException>
<w:LsdException Locked="false" Priority="31" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="32" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"></w:LsdException>
<w:LsdException Locked="false" Priority="33" SemiHidden="false"
UnhideWhenUsed="false" QFormat="true" Name="Book Title"></w:LsdException>
<w:LsdException Locked="false" Priority="37" Name="Bibliography"></w:LsdException>
<w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"></w:LsdException>
</w:LatentStyles>
</xml><![endif]--><!--[if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Courier New";
mso-bidi-font-family:"Times New Roman";}
</style>
<![endif]--><span style="font-size:12.0pt;line-height:150%;font-family:"Courier New""><o:p></o:p></span></p> © Richard Chambers
