PosicFR4 scale for inductive encoders
Posic launches two new benchmarks for the ID1102L and ID4501L linear encoders.
10 of 13
© iC-Haus
The iC-BL bridge module from iC-Haus has a versatile I/O port. This enables several interfaces to be assigned in parallel. On the control side, BiSS line communication is coordinated via the integrated BiSS C or SPI slave interface, so that transmission paths can be realized in many applications. The flexibility is supported by a supply voltage range of 5 V, 7 V or 30 V, an on-chip DC/DC converter for generating a sensor supply of 2.5 V, 3.3 V or 5 V up to a maximum of 200 mA. The 5 mm × 5 mm QFN28 housing also contains a non-volatile OTP memory for the device configuration. Additional sensor data, for example from an I²C temperature sensor, can thus be integrated into the cyclical data transmission. The bridge module can also be implemented as a transmission channel between several microcontrollers. The RS485 transceiver for differential communication is already integrated. The error correction allows communication even in harsh environments with electromagnetic interference fields and enables corrections of up to 4 bytes.
SPS 2022: Hall 4A, Stand 146
10 of 13
