Siko at the SPS 2022Absolute encoders for Industry 4.0
The WV3650M and WH3650M absolute rotary encoders from the second generation of Siko's 3 mm series are compact and, thanks to their new architecture, interfaces such as IO-Link and smart features, are a solution for Industry 4.0 machine concepts.
2 of 13
© Posic SA
Posic is launching two new scales for the ID1102L and ID4501L linear encoders. The TPLS04 scale has a length of 26 mm, while the TPLS05 is 205 mm long. The scale width of 4.5 mm and the thickness of 0.77 mm match the very small dimensions of the encoders, making them suitable for applications with tight installation spaces. The scale is an FR4 printed circuit board with copper strips with an accuracy of ±10 µm and a resolution of up to 0.02 µm. It does not attract ferromagnetic dust or particles, is insensitive to moisture, grease, oil, liquids, does not need to be cleaned before operation and also works in strong magnetic fields. The scale has an adhesive backing with release film for quick and easy mounting. Typical applications are linear direct drives, Z-motion in pick and place machines, robotics, life science devices, microfluidics, microscope stages, piezo motors and plunger coils.
SPS 2022: Hall 4A, Stand 150
2 of 13
