AS-i Safety
Quelle: Bihl+Wiedemann | Inka Krischke,
Monitor and evaluate analog process values
With the AS-i safety analog input module BWU2692, Bihl+Wiedemann has developed a control cabinet module in IP20 with which it is possible to safely monitor and evaluate analog process values such as temperature, pressure and flow.
© Bihl+Wiedemann
The input module for analog inputs has two safe inputs and supports applications up to SIL3/Kat4/PLe. The 22.5 mm wide module monitors two analog signals with 4 to 20 mA, 0 to 10 V or Pt100. Optionally, the signals can be safely compared with each other. The user or the application determines which signals are monitored. Several safe ranges can be set as part of the monitoring. Safe release occurs as soon as the measured values are within one of the maximum eight parameterizable ranges. If the safety analog module is used in combination with a gateway from the company, the current analog values are also transmitted to the respective standard controller.
Hima Group
CEO appointed for Sella Controls
The Hima Group has appointed Carl Ramsden as CEO of Sella Controls with effect from October 1, 2025. According to Hima, this newly created position represents an important milestone in the further integration of the British company into the Group.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
Hima Group
Growth course continued
The Hima Group, a provider of safety-related automation solutions, grew significantly in the 2024 financial year, driven in part by international expansion and an increasing focus on digital solutions.
