EDAG
Heiko Ehmer und Thomas Franke | Inka Krischke,
Reaching into the box
The process of bin picking, or 'reaching into the box', is replacing outdated methods such as vibrating tables with separation technology or manual sorting. What exactly is behind it?
© EDAG Group
A box of screws, supplied by the manufacturer as bulk material, used directly for production, efficiently sorted with the appropriate software support and removed by a robot? That was wishful thinking for a long time. The task "One long screw, please!" can be completed immediately by a human looking into the crate. An industrial robot, on the other hand, cannot do this without first being explicitly taught how to do it. To do this, the process is transferred from the human to the robot - with appropriate adaptations. The robot must be equipped with additional hardware and software to replace its hands and eyes. To do this, the process is first broken down into its basic components:
  • Seeing: Humans see with their eyes, which in the case of a robot, especially an industrial robot, are replaced by one or more cameras with lighting technology. The camera technology can be attached to the robot wrist, to a moving gantry application or statically above the component carrier with the objects to be removed. The cameras then record several images, which are further processed by appropriate software.
  • Recognition: The desired object is identified by a three-dimensional reference model that was previously created by a corresponding computer program. Both different objects and only objects of the same type can be identified in these images. If no object is recognized in this process, feedback is sent to the corresponding control system.
  • Select: Analogous to the stored reference models of the object, various gripping options are also stored. These define how the robot can pick up the object with its gripping tool. The previously identified objects are analyzed and the object that can be picked up most easily by the robot is selected. The object is selected and evaluated according to a previously defined priority list. There are areas that are stored as interference contours - for example, environments in which the robot may collide with the object removal box, steel construction elements, fences or neighboring robots. This is also taken into account when selecting the object in order to avoid a collision during object removal. If no object can be removed without collision, this information is passed on to the corresponding control system.
  • Planning: After selecting the object to be gripped, a so-called path planning is carried out for the robot. For this path planning, appropriate software uses a three-dimensional simulation of the local conditions and their interfering contours. Together with the stored gripping options, the complete motion sequence is created.
  • Execute: Once all previous steps have been successfully completed, the collision-free movement is executed. The robot moves to its target position in accordance with the planned movement, picks up the object and places it at a previously defined storage location in a precisely defined position. The process then starts again.
Bin picking through the ages
Screws as bulk material - picking out a single screw is a challenge for robots.
© EDAG Group
Bin picking applications have been increasingly developed over the last few years. Compared to the early days of bin picking, target recognition is now much more accurate, faster and more effective thanks to better camera technology and greater computing power. Possible collisions between the robot and its surroundings can also be calculated better and faster thanks to more powerful processors.
Long set-up times (tool changes) for gripping tools are no longer necessary thanks to flexible gripping devices and better simulation in advance. In contrast to previous automated solutions for separating, sorting and packing, bin picking is more flexible when it comes to object changes. With classic vibrating tables with separation technology, almost every change in the shape of the object requires a new tool or an adjustment. With the bin picking process, on the other hand, the new object shape and its gripping options are taught into the system and high investments for new tools are not required.
Advantages over human hands
Figure 1: Breakdown of the gripping process of a robot into sub-processes
© EDAG Group
Bin picking is particularly useful when employees perform monotonous and/or risky tasks. The aim here is to protect the workforce and instead deploy them for lower-risk and at the same time more demanding activities. This is particularly important in view of the shortage of skilled workers in order to create an attractive workplace.
One example: punched parts have sharp edges before deburring and therefore pose a high risk of cuts for employees. Cut-resistant gloves restrict mobility, dexterity and dexterity. Gripping small parts is particularly problematic with such gloves. However, this activity can easily be replaced by a bin-picking solution.
Special environmental influences, such as vapors or heat, also pose a risk to humans. However, these have no effect on a robot, whereas a human has to work in such an area with appropriate respiratory masks and, if necessary, protective clothing. Similarly, a robot can relieve employees of heavy components or products that are difficult to reach ergonomically and optimize work processes.
Particularly monotonous, manual activities such as sorting, picking or packing lead to a loss of concentration among employees if there is no variety. As soon as these activities are carried out in short cycle times or under time pressure, unintentional errors occur. Automation with bin picking helps to prevent this type of error.
Further use cases
Figure 2: Left: Camera image with selected screw; right: unprocessed camera image
© EDAG Group
Bin picking can be used for a wide range of applications. The described screw application is a mixture of a pick & place application and the sorting of different goods. Bin picking can also be used for pre-picking or picking and packing parts in logistics. It can also be used for assembly tasks and quality control in mechanical and automotive engineering, the food industry and numerous other sectors. The material and shape of the objects are irrelevant here. Human-robot collaborations are also possible, whereby the robot moves heavy or unwieldy objects and hands them over to its human counterpart, for example.
From manual activity to reaching into the box
Before introducing a bin picking process, a precise analysis of the current process is necessary. This involves answering a number of questions - for example, what range of parts the gripping tool needs to cover, how much they differ from each other in terms of shape and what kind of process is involved. An individual feasibility analysis on site then clarifies the next steps. There are also optional extensions that can be integrated into the process. These include seamless process monitoring with documentation and integration into a higher-level control system.
SEW-Eurodrive
Four robots, one unit
Handling pipes is a major challenge. Especially when they are up to four meters long and space is limited. An application-specific handling and transfer unit with four Scara robots solves the problems.
