Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
SR System-Elektronik is expanding its "SR-Line" industrial monitor family with a 19-inch industrial monitor for control cabinet mounting (19-inch rack). The R-Flat 19/FHD industrial monitor offers full HD resolution of 1920 x 1080 pixels with a width of 84 TE and a height of 8 U. When selecting the TFT (18.5 inch in 16:9 format) for industrial applications, particular emphasis was placed on a 19-inch panel with stable colors and viewing angles. The manufacturer specifies a viewing angle of 178° on all sides, a contrast of 1000:1 and a maximum luminance of 350 cd/m² as key data. The monitor is equipped with an analog and a digital signal input (DVI). The LCD color screen with protective glass (IP65 on the front) is compatible with VGA, SVGA, XGA, SXGA and WUXGA. The OnScreenDisplay (OSD) enables the configuration of contrast, brightness, color balance, image geometry and other parameters. Power is supplied via an integrated wide-range power supply unit.
