Adamczewski at the SPS 2022Manage 32 measuring stations centrally
Adamczewski Elektronische Messtechnik presents the AD-MM 500 FE monitor module. The monitor module can be configured for data output and for reading out individual or multiple measuring points.
10 of 14
© Micro Epsilon Messtechnik
The optoNCDT 1900-6 and 1900-6LL laser sensors expand the Micro-Epsilon laser triangulation sensor portfolio. They operate with a measuring range of 6 mm, providing measuring ranges between 2 and 500 mm. The sensors can be used for measuring tasks in various industries. For example, they are suitable for measuring the film thickness of batteries. The 6LL model with laser line is designed for rough and reflective surfaces. The sensor generates a small oval light spot instead of a light point. This light spot can be used to compensate for inhomogeneous surfaces, resulting in stable signals and high accuracy. In the battery industry, the sensors are used for thickness measurement, among other things. The sensors measure the film from two sides in order to determine the film or coating thickness.
SPS 2022: Hall 7A, Stand 130
10 of 14
