Jumo at the SPS 2022Pressure transmitters for the process industry
Jumo presents the programmable pressure transmitter Jumo Siras P21 AR/DP.
5 of 13
© E+E ELektronik
The HTM502 sensor module from E+E Elektronik realizes precise humidity and temperature measurement without major integration effort. The integrated sensor protection and the mechanically robust housing are suitable for use in HVAC and industrial applications. The sensor module measures humidity and temperature with an accuracy of ±2.0 % RH and ±0.3 °C and can be used in applications from +5 to +60 °C. Unintentional contact with the sensor element is prevented by the housing. The integrated E+E sensor coating protects the sensor element from contamination and corrosion, thus improving the measuring performance and long-term stability. The I²C interface allows integration of the module and offers two operating modes for the measurement: single-shot or periodic measurement mode. Communication speeds of up to 1000 kHz are also supported. The 4-pin connector plug also allows the sensor module to be replaced in the field.
SPS 2022: Hall 4A, Stand 211
5 of 13
