Bosch RexrothctrlX Automation ecosystem
The real-time capable, Linux-based operating system ctrlX OS from Bosch Rexroth, which was previously used exclusively on the ctrlX Core controller, is now available as a separate solution for the industrial environment.
18 of 19
© Automata
Thanks to its IP65/67 protection rating and compact dimensions, the S1-PAC.IP IIoT controller from Automata can be mounted directly on the machine. Its scalable performance and communication interfaces make it suitable for IIoT applications with a focus on communication or control systems for classic PLC and motion applications as well as a hardware basis for visualizations. The CPUs also perform these tasks in parallel. Ethernet interfaces, WiFi and 3G/5G modem create connections to the cloud or local networks and thus enable integration into SmartFactory structures. The OPC UA server serves as a standardized communication protocol. I/Os and drives can be connected via Ethercat. The IIoT controller also offers an expansion slot for local I/Os or additional fieldbus interfaces. In conjunction with Codesys as a soft PLC, even demanding automation tasks can be implemented.
SPS 2022: Hall 7, Stand 281
18 of 19
