Delta Logic
Server for industrial communication
Accon-OPC-Server UA from Delta Logic has been specially developed for the requirements of a Siemens S7 environment. The software enables secure data transfer between OPC server and client as well as S7 PLCs.
The software supports the current OPC UA specification 1.04 and has been certified by the OPC Foundation since the end of 2021. The software from Delta Logic is used wherever an OPC UA-compliant interface is required to access the data of an S7 controller, for example for server-client communication in BDE, MES or ERP. The software was developed for use with Siemens S7-300, S7-400, S7-1200, S7-1500 and Siemens-compatible PLCs. Simultaneous two-way communication (read and write) can take place with up to 255 PLCs. Online symbol import from S7-1200 and S7-1500 PLCs is possible.
