Hilscher
In networked factory and process control systems
With netMotion, Hilscher is expanding its strategy of supporting several real-time Ethernet protocols with firmware-based solutions to include the area of motion control.
© Hilscher
While typical chip solutions for motor control applications usually lack real-time Ethernet connectivity, the 'netX 90' combines industrial communication with multifunctional motion and motor control functions in a single-chip solution. It offers a deterministic, network-synchronized, low-latency solution for FOC-based motor control with position feedback based on Hall sensors or encoder signals for 3-phase PMSM and BLDC motors.
Both motor types are used in industry for a wide range of applications. PMSM solutions can be found in industrial applications with precise movements such as servo drives, hydraulics, pneumatics and many more. A development kit for 'netMotion', consisting of hardware, software and tool components, enables the design of a speed-regulated motor controller with an application profile that is synchronized via an industrial Real-Time Ethernet communication protocol. It is supplied with a generic control application to support developers in the implementation of initial designs. The NXHX 90-MC software development board can be operated directly with Hilscher's 'netX Studio CDT', a free Eclipse-based IDE that contains everything required for the configuration, development and debugging of embedded applications.
Yaskawa
Embedded solutions for automation
The current profichip brand communication chips from Yaskawa include the all-in-one chip Triton, the multi-fieldbus communication chip Antaios, the slice bus slave controller Notos and the world's smallest Profibus ASIC VPC3+S.
