SPS IPC Drives 2018New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2018? Computer&AUTOMATION provides an overview of what visitors to the Nuremberg exhibition halls can expect this year.
With the PWT 100 test device and the PWM 21 test device from Heidenhain, specialists in the service and maintenance of machines and systems have the option of displaying information, evaluating it and analyzing the measuring devices. The PWT 100 is primarily intended for mobile use when checking the function of Heidenhain measuring devices in machines and systems on site in production. It has compact dimensions, a robust design and an integrated 4.3-inch touchscreen. The test device is the successor to the PWT 10, PWT 17 and PWT 18 series, but has a wider range of functions, which are also constantly being expanded through firmware updates. The PWM 21 is designed to impress with low measurement tolerances, can be calibrated and also offers a wide range of functions. As well as being used for commissioning and checking the function of measuring devices, it can also be used for closed-loop diagnostics. Together with the ATS software, the PWM 21 is a complete adjustment and testing package.
