SPS IPC Drives 2018New products in Nuremberg
What new products will exhibitors be presenting at SPS IPC Drives 2018? Computer&AUTOMATION provides an overview of what visitors to the Nuremberg exhibition halls can expect this year.
33 of 75
IZYTRONIQ testing software from Gossen Metrawatt
© Gossen Metrawatt
Gossen Metrawatt is presenting its new IZYTRONIQ testing software with an integrated cloud connection for the first time. The solution makes it possible to map the entire testing process across all devices and document it in an audit-proof manner. Measurement results from different test devices and multimeters can be combined into one test and logged. With the Profitest Prime, the Profitest Master and the Secutest, Gossen Metrawatt is presenting three device series that are already equipped with the new software as standard. The Profitest Prime, available in three versions for low-voltage systems as well as AC and DC high-voltage tests, is optimized for testing the electrical safety of machines and systems. Its range of functions includes all measurement tasks for standard-compliant testing of industrial and IT networks, wind power and photovoltaic systems as well as electrical charging stations. The CAT IV-protected Profitest Master performs all testing and measuring tasks prescribed by VDE 0100 Part 600 in AC and three-phase networks with voltages from 65 to 500 V and frequencies from 15.4 to 420 Hz. Finally, the Secutest model series covers the special requirements for testing protective measures on electrical and medical devices as well as welding equipment up to 400 V.
33 of 75
