Hanover Fair 2018New products at the industrial trade fair
'Integrated Industry - Connect & Collaborate' - this is the motto of the world's most important industrial trade fair, Hannover Messe 2018. Computer&AUTOMATION shows an excerpt of the products that can be seen in Hanover in a picture gallery.
36 of 51
Multi-function four-wire transmitter Dtrans T06 from Jumo
© Jumo
The Dtrans T06 multi-function four-wire transmitter from Jumo is suitable for applications in plant engineering. The mounting rail housing with a width of 22.5 mm and coded plug-in terminals is designed to enable quick switch cabinet installation and safe replacement during calibration and maintenance work. The device can be used with resistance thermometers and thermocouples as well as with WFG/potentiometer and voltage/current signals and converts these input signals into a 0(2) to 10 V or 0(4) to 20 mA output signal. The universal measurement input has a triggering of 22 bits. The 3-way isolation between input and output is designed to guarantee high signal stability even under difficult measuring conditions. For safety-relevant applications, the device enables the configuration of a safe temperature measuring chain with the SIL option in accordance with IEC 61508. This is designed for SIL3 in terms of software and SIL2 in terms of hardware. Jumo SIL temperature sensors are included in the device concept, reducing the planning effort for the SIL design. If a notebook is not available, the device can be configured in four languages via a monochrome LCD display with four buttons on the front.
36 of 51
