Yaskawa at the SPS 2023
Control unit with 36-month warranty period
With the '300S+' high-speed control system, Yaskawa is opening up new prospects, particularly for the replacement of existing solutions. This is because IOs and accessories are fully compatible with the previous system.
© Yaskawa
All hardware components can be replaced 1:1 and used in parallel in mixed operation. The CPUs can also continue to be used largely unchanged so that the existing software can remain in place. Yaskawa provides special support for the corresponding adaptations in the CPUs. The company grants a warranty period of 36 months for the entire extended control system, all components are available directly from stock and will be available until at least 2030. The integrated microchips are based on Yaskawa's own technology. According to the manufacturer, the current version of the high-speed control system is around ten times faster than comparable systems. The PLC CPUs offer a memory size of up to 8 Mbytes (fully retentive). Up to 32 expansion modules are possible per station.
Hall 7, Stand 340
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
SPS 2024
Automation meets innovation
SPS - Smart Production Solutions will take place in Nuremberg from November 12 to 14. Once again this year, organizers and exhibitors will pick up on the trends in the automation industry and present suitable solutions. The introduction of IT into...
