Durabook
AI-enabled rugged mobile workstation
With 'Z14I-HG' Durabook presents an AI-ready Fully Rugged Mobile Workstation with Nvidia RTX 5000/3500 Ada graphics.
The 14-inch system combines up to 682 TOPS Edge AI performance, Intel Core Ultra processors with integrated NPU and Workstation-Class RTX Ada graphics in a MIL-STD-810H, MIL-STD-461G and IP66 certified housing. The workstation enables compute-intensive applications such as real-time 3D rendering, AI inference, computer vision, digital twin simulation and advanced data analytics directly in the field, even at -29 to +63°C. The device is designed for organizations that require high-performance computing and AI directly at the point of use, without dependence on cloud infrastructure. It integrates either an Nvidia RTX 3500 Ada with 12 Gbyte ECC GDDR6 or optionally an RTX 5000 Ada with 16 Gbyte ECC GDDR6 memory. With up to 9,728 CUDA cores and a memory bandwidth of up to 576 Gbit/s, the system offers more than three times the graphics performance of currently available rugged GPU solutions. The combination of Nvidia Ada Lovelace architecture with Tensor Cores and Intel AI Boost NPU creates a hybrid AI architecture for local high-performance analytics. Typical applications include object recognition and automatic inspection, predictive maintenance analysis, sensor fusion in safety-critical environments and AI-supported automation. In a production plant, for example, the system can analyze sensor data from multiple machines in real time. Deviations are detected immediately and maintenance work is planned before a breakdown occurs.
The workstation has a 14.0 inch FHD DynaVue Sunlight-Readable Display with 1200 nits brightness and 10-point capacitive multi-touch. The four input modes finger, glove, water and stylus are supported. The system also offers an extensive range of interfaces with up to four Nvidia-powered HDMI 2.1 outputs for 4K at 120 Hz or 8K at 60 Hz, in addition to a fifth HDMI port, two Thunderbolt 4 ports, VGA, dual LAN and serial interfaces (RS232/RS422/RS485).
