E-T-A at the SPS 2021
Transparency through web server and fieldbus connection
The CPC12 bus controller from E-T-A has a separate 24 V (DC) power supply and thus enables an independent supply to the circuit breakers and records all status information and measured values.
© E-T-A
This data is visualized using the internal web server. The data is also made available to the higher-level control systems via the fieldbus interface.
According to the manufacturer, the bus controller maximizes system and machine availability through clear fault detection, high transparency and remote diagnostics, it enables space savings through the narrow design of the circuit breakers and potential modules and it increases the flexibility of system planning through a variety of different modules that meet the requirements of 24 V (DC) power distribution.
E-T-A at the SPS 2021: Hall 3 Stand 221
E-T-A
Well secured
In the course of digitalization, the demands on power distribution are also increasing. But how can transparency at the 24 V (DC) voltage level be increased and thus improve system availability?
