Spectra
Second source for remote Profinet I/O
The Profinet Remote I/O of the PFN-2000 series from Spectra are suitable for Profinet I/O applications in which, for example, a Siemens S7 or compatible PLC acts as the central control unit and in which other analog and digital signals are to be processed decentrally.
© Spectra
The I/O modules comply with Conformance ClassB and RTClass1 and are therefore particularly suitable for applications with a cycle time in the >1 ms range. The integrated switch with two Ethernet ports enables flexible cabling in different topologies. The I/O signals are connected via push-in plug-in terminals and the module is simply mounted on the top-hat rail. The input voltage range of 10 to 30 V(DC) also copes well with fluctuating control cabinet voltage. Spectra'sI/O range extends from the universal 8DI/8DO module to 10AI with individual channel configuration for mV, V, mA or T/C type J/K/T/et cetera up to 4AO with 0 to 10 V or 0/4 to 20 mA output. The software integration of the PFN-2000 modules into the Profinet project is carried out as usual by importing the associated GSDML file supplied into the engineering tool.
EUCHNER
Customized solutions for smart automation
In a world of increasing automation, functional safety is essential. Plant operators not only have to comply with legal requirements, but also ensure efficiency and availability. For more than 70 years, EUCHNER has been supplying customized...
