AMC
Next generation PoE injector
The EKI-2701MPI-5G is a PoE injector of the 'EKI-2701' model series and is compatible with IEEE 802.3af/at/bt. It supports multiple data rates (10M/100M/1G/2.5G/5G) and IEEE802.3bt 90W PoE output.
© AMC
The PoE injector supports backward compatible 2.5 and 5 Gbps data rates to provide Wi-Fi 6 capabilities to existing wireless infrastructures. It also serves as a PoE PSE, delivering up to 90 W of output power to IP cameras, Wi-Fi 6 access points and other connected devices. The injector's PoE standard is backward compatible for 15, 30 and 60 W PoE PD devices, simplifying network infrastructure upgrades. The injector flexibly uses standard and high-power PD (Powered Device) devices to transmit data and power simultaneously over an Ethernet cable, reaching a distance of up to 100 meters. Two power inputs are supported via a pluggable terminal block or DC socket. Installation options for DIN rail and wall mounting are available.
