SSVYou can't do without IoT platforms!
IoT platforms are already available today in very usable versions. But what building blocks do the platforms actually consist of and what should you look out for if you want to use a platform?
<p>In addition to the application logic, AWS IoT consists of a modular IoT hub that enables MQTT, HTTP 1.1 and WebSockets connections on the protocol side, with a clear focus on MQTT. In terms of security, the devices are expected to support TLS 1.2 with mutual authentication and are equipped with an X.509 certificate plus a private key. All security functions can be set very finely via a management system.</p> © SSV
