U.I. Lapp
Ethernet controllers
Lapp has also been offering switches for two years. Further versions will be added for SPS 2019, including the smallest Profinet switches on the market, according to the supplier.
Lapp is expanding its range of Ethernet switches to include managed and unmanaged devices. The picture shows the Profinet switch 'NF04T'.
© U.I. Lapp
In addition to the cables, Ethernet data connections also depend on the peripherals, including the switches as pilots in data traffic. Lapp - originally a provider of integrated connection systems - is launching new switches on the market to ensure that cables and peripherals work well together. The 'Etherline Access' switches are available in different versions with four to 16 ports, also in combination with ports for fiber optic cables and as a variant with Power over Ethernet.
Decentralized control cabinets in production are often cramped; sometimes it is not even possible to close the door when they are fully equipped. Profinet switches with four, eight and 16 ports are available for such cases. With dimensions of 32 mm x 58 mm x 76 mm (Ethernet Access NF04T), they are the most compact on the market and can be installed flat on the DIN rail. The managed switches fulfill Conformance Class B and can be configured via a web interface.
Another new switch serves as a broker between IP networks and is used where there are conflicts due to multiple IP addresses. It has three LAN ports and a WAN port that connects the switch to a higher-level company network. Its NAT functionality translates the same IP addresses at machine level into different IP addresses at company level. Or the switch translates different external IP addresses into a different address range for the network at machine level. Port forwarding and routing mode are also on board.
In order to achieve high transmission rates over long distances, two other managed switches each have two SFP ports in addition to eight RJ45 ports for connecting fiber optic cables, including for fast Gigabit Ethernet. The switches can withstand temperatures between -40 and +75 °C and are protected against the ingress of foreign bodies in accordance with IP40. Suitable SFP standard modules for converting the light signal into electrical signals are also available.
A useful feature of Ethernet cables is that they can transmit electrical energy as well as data. Although the performance is low, it is sufficient to supply cameras in quality monitoring or Wi-Fi access points, for example, and a separate power supply can then be dispensed with. A new unmanaged switch from Lapp has four RJ45 ports with Power over Ethernet to supply power to the connected peripherals as well as a port for Fast Ethernet.
Lapp
Growth against the trend
Lapp, a provider of integrated solutions and products in the field of cable and connection technology, successfully concluded the 2018/2019 financial year and increased its turnover by 6% to over EUR 1.2 billion.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
