Monitoring of data lines
Günter Herkommer,
Details of the Ko²SiBus research project presented
The Ko²SiBus research project aims to develop new methods for the cost-effective monitoring of data lines in running industrial plants. On February 21, representatives of the consortium met to exchange information.
The Ko²SiBus project runs until 31.05.2019.
© IMMS
The wired Ethernet-based communication lines for data exchange and the networking of industrial systems are not generally monitored continuously at present. One reason for this, in addition to the large number of Ethernet cables, is that most of these cables are concealed and difficult to access. Until now, cable breaks and faults have usually had to be investigated during machine downtimes and away from the system using additional measuring devices.
Against this backdrop, the two-year research project "Ko²SiBus - Continuous and cost-effective signal monitoring for industrial bus systems" was launched in mid-2017. As part of this BMWi-funded project, the Institute for Reliable Embedded Systems and Communication Electronics (ivESK) at Offenburg University of Applied Sciences and the team from the Chair of Measurement and Sensor Technology at Chemnitz University of Technology are working together with the IMMS Institute of Microelectronics and Mechatronics Systems to develop new solutions that will significantly reduce downtimes and maintenance costs in industrial plants that are attributable to faults in data cables that were previously difficult to detect.
The new concept should also allow monitoring data to be passed on via a standardized and open interface, making it easy to integrate into customer-specific monitoring solutions. The solution should be able to be retrofitted into existing systems, for example as an extension for switches, and integrated as a feature directly into network nodes of Industry 4.0 systems.
The project committee consists of the following industry partners: Bosch Rexroth, Gemac - Gesellschaft für Mikroelektronikanwendung, Hilscher, Indu-Sol, Pilz, R. Stahl Schaltgeräte, Renesas Electronics, Sick, Stackforce and Turck.
TU Chemnitz researches methods for cable diagnostics
Chemnitz University of Technology is providing the theoretical groundwork for the development of the embedded cable diagnostics process in Ko²SiBus. For this purpose, a large number of existing test methods are being compared and analyzed, such as Time Domain Reflectometry (TDR). The main challenge here is to use the diagnostic tool in industrial plants without interrupting their operation. The aim is to achieve a significant improvement on the current state of the art. On the basis of a specially adapted demonstration network, the theory is to be compared with practice, among other things by looking at typical cable fault events.
HS Offenburg works on communication interfaces
In the project, Offenburg University of Applied Sciences is primarily concerned with the necessary communication interfaces via which the analysis data is passed on to higher systems. Standard protocols are used, which have to be adapted and optimized for use on small, low-power microcontrollers. Offenburg University of Applied Sciences is also implementing the corresponding controls for the analysis functions.
IMMS designs circuit concepts
IMMS will use this input to design an embedded system and develop suitable circuit concepts. Based on the know-how from developments for sensor solutions, including for monitoring industrial plants, a system will be implemented in Ko²SiBus that tracks physical signal parameters using integrated analog and digital components and reports deviations to a monitoring center. The functionality is to be tested using a demonstrator to be built by IMMS.
U.I. Lapp
Entry into the switch business
The Stuttgart-based Lapp Group - previously known for cables, wires and connectors - is expanding its connection technology portfolio to include switch technology. Jürgen Greger, Product Manager Automation & Network, explains the strategy behind...
Fieldbus technology
The future of CANopen
Similar to the automotive industry, industrial automation also requires more and more bus bandwidth. In addition, the cloud is becoming increasingly important in terms of communication. How does the CAN protocol, which has long been established in...
Comment
TSN - what it needs now!
TSN is to form the backbone of the new automation architecture! However, there is still a lot of homework to be done before the communication standard can be implemented quickly and extensively in industry.
Sensors 4.0
The intelligent multi-sensor system
As part of the research project 'Robust multi-sensor technology for condition monitoring in Industry 4.0 applications', experts from research institutions and industry are researching development methods for intelligent multi-sensor systems. The...
Sick
Sales growth in a turbulent market environment
Thanks to innovations and a focus on strategic industrial markets, Sick was able to moderately increase its sales in the 2025 financial year. In a turbulent market environment, the company was able to maintain its position and gain market share with...
