IoT-Maxx
Condition monitoring made easy
The combination of the numerous interfaces of the IoTmaxx gateways and the intuitive user interface of the Anyviz cloud makes it possible to set up the visualization of machine data in just a few minutes.
© IoTmaxx
Regardless of whether analogue or digital signals are to be evaluated directly or the connection is to be made via a fieldbus such as Modbus TCP, Modbus RTU or OPC UA, IoTmaxx provides the interface and Anyviz the visualization. The cloud adapter for connecting to the cloud is pre-installed on the gateways and only needs to be linked to the Anyviz customer portal by entering the Anyviz project number. The cloud archives the data and uses visualization widgets to quickly create a clear dashboard.
More complex formulas for converting and evaluating the transmitted data can also be stored. Thanks to the LTE technology used, data can be visualized in the cloud from almost any position with low latency.
Siemens
Visualization overcomes boundaries
Until now, the worlds of operation and monitoring were separate: here machine-oriented operation, there plant-wide monitoring. Modern visualization systems act as a gateway from OT to the IT world, enabling a consistent solution for HMI and SCADA...
