1 of 13
Sensory product innovations in spring 2015
Plicsled display module from Vega
© Vega
With the Plicsled display module from Vega, the switching status of a sensor can be read from a distance and even in strong sunlight. The module is compatible with all sensors in the 'plics' family with relay output (Vegaswing Series 60, Vegavib Series 60, Vegawave Series 60, Vegacap Series 60 and Vegamip Series 60). There is no need for external wiring, which minimizes the time required for installation. Power is supplied via the relay electronics. The second relay output is used to control the switching status display. Depending on the version, the switching status is displayed in two colors - red-green or yellow-green. The display module is integrated directly into the plics sensor housing and thus assumes its protection class.
1 of 13
