© Telemeter Electronic
Telemeter is replacing the 'CPX400' dual power supply series with the CPX400D models and the programmable CPX400DP variant. They offer power up to 840 W (420 W per channel), voltage up to 60 V and currents up to 20 A. The interfaces USB, GPIB, LXI (LAN) and RS232 integrated in the CPX400DP model enable connection to automatic measuring systems. Use in 'Labview' systems is also possible. The "Setting-Lock" function makes it possible to save the set voltage and current values at the touch of a button and prevent unintentional adjustment. The saved values are digitally stabilized. As long as "Setting-Lock" is activated, it is not possible to change the values either intentionally or unintentionally using the rotary controls. The "V-Span" function makes it possible to set a self-defined voltage range (Vmin, Vmax). The output voltage can then only be changed within the set range. Rear connections and a 19-inch installation kit simplify system integration.
