© Meilhaus Electronic
Meilhaus Electronic presents the
modular data acquisition and switch system M300 from Rigol. It allows a maximum of 320 switch channels per device, whereby the device can be used both with a controlling PC and independently of the PC. It can also be equipped as a pure switch system (five slots) or as a combined measurement and switch system with a digital multimeter module (one slot for the multimeter, four slots for switching modules). Ten module types are available, including 32 and 64-channel multiplexers or reed multiplexers, mix multiplexers (20 voltage channels, four current channels), 16 SPDT switchers and a 4x8 2-wire matrix switch. The multifunction module offers four 8-bit digital I/O ports (TTL, CMOS and others), four totalizers and four analogue outputs. The device allows interval scanning with storage of up to 100,000 measured values with time stamp. If required, several devices can be cascaded. The device has a 4.3 inch graphical LCD with an intuitive GUI and offers USB 2.0 fullspeed host and device, LAN (LXI-C), GPIB and RS232 (SCPI command set) interfaces.
