Vision Components at Vision 2024
Easy and flexible to integrate
© Vision Components
With the 'VC MIPI IMX900', Vision Components is launching an industrial-grade camera module that integrates the new 'IMX900' image sensor from Sony.
The global shutter camera from Vision Components offers 3.2 megapixel resolution and high light sensitivity down to the infrared range. With a sensor diagonal of just 5.8 mm, the ultra-compact module can be integrated easily and flexibly. On request, the manufacturer can also supply a GMSL version of the camera module for connection with coaxial cables up to 10 m long. This option is now available for all VC MIPI cameras. The company has developed an ecosystem of components and resources around the VC MIPI cameras.
Vision 2024: Hall 8, Stand C31
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
Evotron
Multicolored area light
Evotron has introduced the 'A82x82' series of diffuse monochrome and multicolored surface lighting. New features have been added to the implemented 'Lumisens' technology.
