Rauscher
Inka Krischke | Tiffany Dinges,
Two integrated cameras
Matrox Imaging has launched AltiZ, a 3D laser profile sensor that works on the principle of laser triangulation. However, two cameras are integrated into its housing instead of just one.
© Rauscher
Simultaneous observation of the laser line with two opposing optical sensors reduces the risk of gaps in the image capture, as object contours that cannot be detected by one camera due to shadowing are captured by the second sensor. Depending on which of the four available 'AltiZ' models is used, surfaces can be captured on the basis of up to 1984 pixels per profile with an accuracy of up to 4 µm. The possible speed of image acquisition is a profile rate of up to 2500 profiles per second. The sensors can be operated alternately to further increase the image capture rate if required, thus doubling the profile rate.
The conversion of the recorded profile data into the output 3D point cloud and/or the 2.5D depth map takes place within the camera without the use of a PC.
Rauscher
Precision in the large field of vision
Rauscher has six 'Basler boost' cameras with sensors from the 'XGS' series from ON Semiconductor. According to the supplier, the CoaXPress cameras are suitable for applications that require high resolutions and precision in a large field of view.
Leuze at the SPS 2024
Double focus
With the 'DCR 1048i OCV', Leuze is expanding its Simple Vision portfolio with a further functionality: The sensor can both read 1D/2D codes within an application and check the quality of a print using the OCV method.
