Image processing PCs
Quelle: Vision & Control | Inka Krischke,
SPS becomes superfluous
The Vicosys 5400 image processing PC from Vision & Control performs tasks such as blob analysis, gray value testing, 360° pattern search or rotational position more than twice as fast as its immediate predecessor, the Vicosys 4400.
© Vision & Control
This makes the image processing system particularly suitable for complex tasks and time-critical program sequences. The robust, 147 mm × 171 mm × 230 mm housing is externally identical to that of the standard Vicosys 5300 version - however, instead of an Atom E3827 processor, it uses an Intel Core i3-6102 CPU. It is supported by 4 Gbyte DDR4 RAM and a 4 Gbyte Compact Flash card. The system can be integrated directly into a machine environment and makes a PLC superfluous. The image processing PC works with a wide variety of image sources; both high-resolution (30 megapixels) and high-speed (300 fps) images from up to 16 cameras from various manufacturers can be combined as required and operated simultaneously. A wide range of connections, such as four 4 GigE Vision camera interfaces as well as the process interfaces CANopen, Sercos3 (in preparation), Modbus and four opto-decoupled digital I/Os enable a variety of configuration options. Video output is provided via a DVI output.
IDS
AI and streaming meet robustness
IDS Imaging Development Systems is expanding its range of AI cameras with the 'IDS NXT oslo'. The model combines artificial intelligence with video streaming and recording functions in a compact, industrial-grade housing.
Digital Twins
With real-time data against disasters
A digital twin is more than just a two- or three-dimensional digital copy. It combines precise data with intelligent analysis and solves complex challenges. With locations in Paderborn and other cities, Eviden relies on the combination of artificial...
