ifm electronic at the Logimat 2024
Communication via IO-Link
With the 'O2I' multicode reader, ifm shows how IO-Link can be used in modern vision systems. Applications can be found primarily in logistics.
© ifm
The vision sensor from ifm checks the quality of codes and text information or ensures traceability along the entire process. For use in dark or shaded environments, it is equipped with integrated RGBW lighting so that, according to the manufacturer, it can also detect difficult color combinations between code, text and background. The reader uses the COM3 standard with a speed of 230.4 kbaud for data transmission via IO-Link. For better transferability, data with a size of more than 32 bytes is automatically divided into several blocks and therefore transferred quickly to the controller. In addition to transmission, IO-Link also simplifies the handling of the multicode reader, which can be set using a teach button. To do this, it is aligned with the code and then automatically performs focusing, code type detection and exposure adjustment.
Logimat: Hall 8, Stand 8F51
ifm electronic
Not just clean, but pure
Water as it comes out of the tap does not pose any major challenges for process sensors. The situation is different when treating ultrapure water: The sensors used in such a process have to perform and withstand a lot more.
ifm
A better view for robots
3D cameras in autonomous vehicles and robots must always have a very precise view of their surroundings and be able to reliably recognize objects in their environment. ifm is working together with Ravensburg-Weingarten University of Applied Sciences...
ifm
Reinforcement in the area of wireless sensors
Sentinum has been part of the ifm group of companies as a wholly owned subsidiary of ifm group services since mid-May. The start-up from Nuremberg develops and sells wireless sensors that are mainly used for applications in the smart city and smart...
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
