IDS
Cameras for embedded and volume projects
The low-cost portfolio from IDS, which specifically addresses price-sensitive applications, is being expanded to include the 'uEye XLS' camera family.
© IDS
This camera family from IDS are tiny board cameras with dimensions of 29 mm x 29 mm x 7 mm, which have been reduced to essential camera functions. Previously, the low-cost portfolio included the camera families 'uEye XCP' (closed zinc die-cast housing, 29 mm x 29 mm x 17 mm) and 'uEye XLE' (different variants from board models to closed plastic housings). The new USB3 cameras are compatible with the Vision Standard, have a Micro-B connector and are only available as board versions with or without C/CS or S-mount lens holders. They are plugged directly into the lens holder. Users can choose between different sensors from 2 to 12 MP. Thanks to their very low heat generation, the cameras are particularly suitable for device construction and embedded vision applications.
IDS
'Enabler' for factory automation
The more consistently all components involved in the production process communicate with each other, the more autonomous the process can be. Machine vision is a key technology for a production process in which production lines, robots and machines...
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
