ProductsNew power supply products
In a product picture series, Computer&AUTOMATION presents the latest power supply products - from industrial power supply units to load-break switches.
Mico Pro is the new current monitoring system from Murrelektronik. It monitors load and control currents and detects critical moments, signals limit loads and switches off faulty channels in a targeted manner. In the modular system for 12 and 24 V (DC) operating voltages, components are selected from various modules and plugged together with a power module to form a system. You can choose between narrow modules with one, two or four output channels. The tripping currents are either fixed (2, 4, 6, 8, 10 and 16 A) or can be flexibly adjusted from 1 to 10 A or 11 to 20 A. The system has an integrated potential distribution concept for +24 V (or +12 V) and 0 V and is designed to simplify control cabinet wiring. There are connection options for +24 V and 0 V on each channel. The bridging system, consisting of two busbars and lateral spring contacts for contacting diagnostic and control signals, is designed for a total current of up to 40 A. All inputs and outputs are equipped with push-in spring-loaded terminals. The system can be cascaded: a further Mico-Pro station can be connected to a Mico channel.
