Rosenberger OSILWL in a harsh environment
Until now, there have often been concerns about reliability and manageability when using fiber optic cables (FO) in harsh environments. However, current plug contacts also enable safe fiber optic connections in industrial environments, aviation and medicine.
<p>The Size 12 lens plug contact from Rosenberger OSI in pin and socket versions is suitable for use in circular connectors, but can also be used in hybrid systems, such as those commonly found outdoors and in industrial environments where the contacts need to be sealed against external influences.</p> © Rosenberger OSI
