Elobau at the SPS 2022Seal-free suction lance
Elobau launches the eloLance suction lance for use in interchangeable canisters. Suction lances combine the functions of liquid withdrawal and level measurement.
The WV3650M and WH3650M absolute rotary encoders from the second generation of Siko's 3 mm series are compact and, thanks to their new architecture, interfaces such as IO-Link and smart features, are a solution for Industry 4.0 machine concepts. The two rotary encoders, which are available as either solid shaft or hollow shaft versions, can be designed with an SSI or IO-Link interface. The IO-Link interface is integrated according to the latest standard in version 1.1 in accordance with IEC 61131-9. The sensor transmits the information relevant to system availability, such as temperature, operating hours and other diagnostic data together with the position and speed values. The multi-turn version is gearless and battery-less and, depending on the version, can record over 16 million revolutions and therefore a range of 24 bits. Both encoder versions are robust. With a protection class of up to IP67, a temperature range of -40 to +85 °C and high shock and vibration resistance, they are suitable for industrial applications and factory automation.
SPS 2022: Hall 4A, Stand 301
