Elobau at the SPS 2022Seal-free suction lance
Elobau launches the eloLance suction lance for use in interchangeable canisters. Suction lances combine the functions of liquid withdrawal and level measurement.
The FT 25-RLHP time-of-flight sensor from Sensopart uses red light to detect objects up to 1.5 m away. The measuring process is housed in a compact miniature housing. This means that the sensor can be integrated into systems where space is limited. Its light spot is small and precise, while laser class 1 allows operation without protective measures. A window mode, which can be activated by pressing a button, also enables area monitoring: non-relevant distance areas can be masked out, for example the foreground and background of a conveyor belt. The switching frequency at which the sensor should work can be set. In addition to a digital switching output, the sensor has an IO-Link interface of specification 1.1.3. and the smart sensor profile. Typical applications include checking the presence of boxes and trays when they are removed from a high-bay warehouse, checking the position of components in assembly processes or for material flow control.
SPS 2022: Hall 4A, Stand 411
