Conta-Clip
Also with push-in connection
Conta-Clip now also offers the DIN rail relay bases of the 'PRS' plug-in relay system in versions with push-in connection.
© Conta-Clip
Thanks to the tool-free wire insertion, the sockets in the new PPRS series, which are available for relays with 1, 2 or 4 changers, significantly reduce the time required for wiring, according to Conta-Clip. Integrated pushers, which can be operated without special tools, are used to release the inserted wires. The relay sockets are designed for a rated voltage of 300 V and can be flexibly configured with PRS relays for voltage ranges from 12 to 220 V(DC) or 12 to 230 V(AC) as well as the corresponding plug-in modules with LED status display. Each connection also has a test tap for easy checking of the voltage applied. The pluggable and touch-proof external cross-connection system 'AQI/PPRS' is available as an accessory for the demand-oriented distribution of potentials between bayed base modules. Other equipment options include snap-on retaining brackets that hold the plugged-in relays in place if required.
New products
Beckhoff simplifies AI training
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At the press conference, the company from Verl also presented some technological highlights.
Beckhoff
AI training made easier
An evolutionary development every year, a revolutionary leap every five to seven years - this is how Beckhoff aims to secure its technological leadership. At Hannover Messe, the company from Verl also presented some technological highlights.
