Stepper motors
Quelle: Dynetics | Lukas Dehling,
Torque up to 78.5 mNm
Nidec Servo has expanded its stepper motor product portfolio with two new models.
© Dynetics
The KV2810 and KV5910 bipolar devices are hybrid stepper motors with ball bearings and generate a torque of up to 78.5 mNm at a step angle of 1.8°. The KV2810 model has dimensions of 28 mm × 28 mm × 9.4 mm and the KA5910 model measures ø63 mm × 9.6 mm. According to the manufacturer, the motors are suitable for applications such as SMA devices, lighting systems or surveillance cameras. Stepper motors are successfully used in positioning control systems. The driver electronics for this are cost-effective, and each control pulse generates a step with a defined angle of rotation.
SEW-Eurodrive
Starter set for aseptic area
Constantly changing consumer trends, smaller batches and sustainability demand more flexibility and modularity in the production process from the beverage industry. A starter set helps to adapt machines and systems to the market.
